エクスポートの上限について
  • February 7, 2025
  • 65 views
F01
Hello.
Is there a size or data capacity limit when exporting?
I was concerned that some of my exports were exported at a reduced size than the original size.
Best answer by Junko3
Hi ​@F01 , Thanks for reaching out about this!
By default, Figma exports images with a DPI of 72. If you’d like to get a higher resolution, you can try adjusting the export scale. “Export settings” section of this guide explains how the DPI changes depending on the settings you use: Export formats and settings
Also, Figma automatically reduces the size of images that are larger than 4096px (in either width or height) when they're imported. This article has more info on that: Add images and videos to design files.
Hope that helps and thanks again for reaching out!
  • Figmate
  • February 12, 2025
