Bug: Copy and paste of images doesn't work
  • July 12, 2025
  • 24 replies
  • 1884 views
Finn_BR_Studio
Hi everyone,
since the last update I’m experiencing issues with the copying of images into other frames. It seems like the image isn’t stored in cache.
Does anyone know how to fix it?
Best,
Finn
Tom Reem
  • Figmate
  • July 12, 2025
Hey ​@Finn_BR_Studio — thanks for flagging this, and sorry to hear you're running into trouble copying images.
I just tested this in a Figma Design file on my end and was able to copy and paste images as expected, so let’s see if we can narrow down what might be causing things to behave differently on your side.
A few things to double check:
  1. Are you using the Figma Desktop App or a web browser? If it's the Desktop App, is it updated to version 125.5.6?
  2. If you're using a browser, which one? And do you have any extensions or plugins installed that might affect copy/paste behavior?
  3. Does this happen with all images and files, or just a specific one?
  4. Does this happen when selecting images directly from the canvas, from the layers panel on the left, or both?
If everything checks out and you're still seeing the issue, the best next step might be to reach out to Figma Support so they can take a closer look. When you do, it’s helpful to include:
  • the link to this Forum thread for context
  • a screen recording of the issue (including left/right panels, if possible)
  • a link to the affected file
  • edit access for support-share@figma.com.
Let us know what you find — happy to keep digging in if needed! 🙏🏻
Julia Meni
  • July 15, 2025
I am experiencing the same issue in all of my files… I have quit Figma, re-started my computer… Everything and still have the issue.
Finn_BR_Studio
  • July 15, 2025
Hey ​@Tom Reem, thank you for your reply!
1. I m using the Figma Desktop App, Version 125.6.4
2. I m using a few plugins but didnt install one lately. Non of them is copying image related.
3. Its not working with all images/videos. Also across both my accounts
4. Copying an image from the canvas is working, but its not working when I double click it and copy it from the Fill panel to implement it into another frame.
Best
Finn
Julia Meni
  • July 16, 2025
@Finn_BR_Studio I found a solution in another post that could be useful, for now, while the bug isn’t fixed.
I hope this helps!
Finn_BR_Studio
  • July 16, 2025
@Julia Meni Hi Julia, thank you so much – it worked for me! Temporary this is a good workaround
@Figma_Support This is still not the most efficient way to copy/paste images from the fill panel. Please fix this soon as it slows down the working process significantly.
Matilde Corina
Hi everyone,
Best,
Finn
I have the same issue! ​@Figma_Support
Tom Reem
  • Figmate
  • July 21, 2025
Hey ​@Finn_BR_Studio, thanks for confirming — I’ve opened a ticket on your behalf including those details with our Product Support team so they can take a deeper look into this. Please check your inbox for case number 1438826 and follow the next steps — this will help us investigate further. Really appreciate you collaborating with us on this.
@Julia Meni, thanks for sharing the solution above.💡 And ​@Matilde Corina, I’m sorry to hear you’ve run into this as well. I haven’t been able to replicate the bug on my end yet, but I’m keeping a close watch for any updates and will share more info here as soon as I have it.🔍
Annika7
  • July 29, 2025
Just here to say that a few people on our web design team are having the same issue (but not everyone). 👋
Digital Nomads
Hi, our team is also having this issue as well now.
Has recently occurred in the last 2-3 days with the new update. Any solutions so far?
andrea-hg
  • Active Member
  • August 3, 2025
I’m algo having this issue. It’s paaaaaaainfuuuuuuuuul & extremely time consuming for our team 😟
Any updates?
Tom Reem
  • Figmate
  • August 4, 2025
Hi everyone — I really appreciate you continuing to surface this, and I’m sorry for the disruption this issue is causing. I’ve checked in with our engineering team, and they’re actively working on a fix.
While I don’t have a specific timeline to share just yet, I’ll circle back here with any new updates as soon as I have them. ⏳
In the meantime, a few designers have reported success with this method:
From the Fill panel → select the thumbnail by clicking on the left of the image. The element will turn blue, and you’ll be able to copy or paste the image by pressing Cmd + C or V. For an illustration, have a look at the GIF image in this thread provided by ​@Nellya.
Hope that helps in the short term, and thanks again for your continued patience.
Jan_Haeck
  • August 5, 2025
Same issue here! Lost the functionality of copy pasting images directly into frame sometime within the last month.
Figma App 125.6.5
on Macbook Pro M3 Max running Sequoia 15.5
Jan
Tom Reem
  • Figmate
  • August 5, 2025
Hi everyone, quick update from our side: I just checked in with the engineering team, and they’ve pushed a fix to production that should resolve this issue. ✅
💡 If you haven’t already, try giving the tab you’re working in a quick refresh → copy/paste functionality should now behave as expected.
Thanks again for your patience while we worked to get this resolved. Let us know how it goes, and if any questions remain.
Atomicvi
  • September 3, 2025
Good day,
As of September 3, 2025, the problem remains the same. I’m using the Desktop App (latest version). If I copy any image (any size) from any browser on MacBook with Command+C and try to paste it with Command+V — whether directly onto a frame or into the Fill panel — nothing happens. It simply doesn’t paste as it used to before.
Could you please let me know if there is any update on this issue?
Atomicvi
  • September 4, 2025
Good day,
As of September 4, 2025, the problem remains the same. I’m using the Desktop App (latest version). If I copy any image (any size) from any browser on MacBook with Command+C and try to paste it with Command+V — whether directly onto a frame or into the Fill panel — nothing happens. It simply doesn’t paste as it used to before.
Tom Reem
  • Figmate
  • September 14, 2025
Hi ​@Atomicvi — thanks for following up, and I’m sorry for the continued trouble. I checked on this issue today and it should be resolved and working as expected. Have you seen any improvement on your end?
If the problem is still occurring, it would help us get on the same page within the file you’re working in. When you have a moment, could you reach out to our Product Support team directly and include:
  • a full-size screen recording of the issue (if possible)
  • make sure support-share@figma.com has ‘can edit’ access.
Thanks again for keeping us accountable with this — I’ll keep an eye out for any additional reports and updates.
Natacha Simoes
Hi, I just googled this issue and ended up here. I believe this is not working again. I’m trying to copy assets between 2 different account and it doesn’t work.
Thanks
Gayani_S
  • February 12, 2026
Hey ​@Natacha Simoes, thanks for flagging this!
On the file you’re copying from, do you have Can View or Can Edit access?
Anyone with Can View access should be able to copy and export assets, unless the file owner has specifically restricted copying and sharing
A couple other things that would help to know:
  • Are you using the Figma Desktop app or the web browser?
  • If you’re experiencing this in the browser, which one?
  • Is everything updated to the latest version?
  • Do you have any browser extensions installed that could interfere with clipboard behaviour?
Also, when you try to paste  does nothing happen at all, or do you get an error message?
Thank you for your help!
Natacha Simoes
Hi, thanks for getting back to me!
Yes, I have edit rights on the files I was copying over. As it was 2x different accounts, I was using Google Chrome and the desktop version, I believe they are the latest version yes, but I will check before trying again. It’s not a big issue, it was more of an matter of saving time as I have original files for everything.
No error message, just a black space instead of the image.
Thanks again!
Natacha
Gayani_S
  • February 17, 2026
Hey ​@Natacha Simoes, thank you for sharing those details!
Copying and pasting images between files (even across different accounts) should work, particularly if you have edit access and are using the latest versions.
Before we escalate, a couple quick things you could try:
  • Try pasting into a new file to see if the issue persists.
  • Test in an incognito window (browser) to rule out extensions.
  • If using the desktop app, try a quick reinstall.
If it’s still happening, a short screen recording showing the copy/paste flow (including the source file and destination file) would be incredibly helpful. I can then pass that along to the team internally so we can investigate further.
Preet Gangrade
You can add all the AI features you want, but if the most basic functionality doesn’t work, it completely undermines everything else. This has been extremely frustrating and constantly breaks my flow while designing.
This is a simple, expected interaction. The fact that it isn’t working makes the product feel unreliable rather than innovative.
For context, I’ve already updated apps and browsers, cleared cache, and gone through all the standard troubleshooting steps. This shouldn’t require workarounds. It should just work.
Please fix this.
  • April 9, 2026
Hi ​@Preet Gangrade, thanks for chiming in here!
I completely understand your frustration, and you are correct basic functionalities should simply work for our users consistently, a expected.
May I ask what OS are you using? And how are you trying to copy and paste images into Figma?
With these details, we can pass this along to our team to try and reproduce the issue. I just tested this on my macOS device using the desktop app and a Google Chrome browser. I’ve tried to copy and paste using the right-click menu, the shortcuts Cmd + C and Cmd + V, as well as dragging and dropping images from my desktop.
Everything is working as expected on my end, so I would love to get more details from you on the exact device and steps our team should be taking to try and replicate the issue that you are experiencing.
Preet Gangrade
@djv It’s macOS Sequoia 15.7.4  and to your question of how I am copy pasting, I have done it in all ways possible, drag and drop, cmd + c/x, cmd V, right click.
Celyn_L
  • Figmate
  • April 10, 2026
Hi ​@Preet Gangrade — thanks for providing the additional context and for walking through the different methods you’ve already tried, that’s really helpful.
I can see that you’ve also reached out via support ticket #1840157, and I’ve gone ahead and passed along the details you’ve shared here to the team, along with a note to help increase visibility on your case.
Please keep an eye on your inbox, as the team will follow up with you directly there as soon as they have an update.
We appreciate your patience in the meantime 🙏
