Feature request: "Variant swap" within component properties
  • May 16, 2022
  • 13 replies
  • 3098 views
Michael_Riddering
Right now if I use a subcomponent I can only add an “instance swap” which doesn’t help me a lot of the times.
For instance, if I embed a toggle component with an on/off variant there is no way for me to control that toggle switch at the parent level.
More info 👇
typefully.com
Ruben_de_Wit
I think this is exactly what I am missing in Figma right now.
What I often encounter is the hassle to swap an icon within a button.
I like to make one icon component with variants, because I don’t like the cluttering when each icon is a seperate component.
The only ‘solution’ (more like workaround) is to drill down layers and swap the variant, like @Michael_Riddering describes.
So I would absolutely welcome the “Variant swap” property!
Visualisation of my desires:
Bruno_Garcia1
  • May 16, 2022
This would be such a nice improvement to the feature!
Brian_Saunders1
Agree that this should be a fast follow on the component properties feature. For a couple of components I’ve moved them out of variants to allow me to use instance swap properties instead, but that’s not really what I wanted to do for various reasons.
Martin_Sturk
I have the same problem.
I have a design system that has a lot of components within components to make it modular and easy to use for the user of the ds.
For example: I have an ancestor button that is used within all other different types of buttons (to keep consistency and make it easy for changes all over the ds). In that button I have my label, which due to the component within component is not selectable with the text property from the top component.
Screenshot 2022-05-17 at 08.43.32
Making variant swap and other properties option usable within stacking component, should have been a feature that was shipped with this launch 🙂
megaroeny
  • May 31, 2022
Big 👍 on this one. One main thing that made me stop attempting to update some existing component sets.
Something else related to this - I don’t want to have to publish “internal” (hidden) components, just for them to show up at the surface/root level of the component props. I want to keep those hidden, but still allow them to be swapped on instances.
Thanks for posting this request Michael! 🙏
TheJMoore
  • June 8, 2022
+1 on this feature! I believe Sketch had some nice symbol nesting swapping, and it’s something I’ve longed for in Figma since the beginning … even more so lately with component properties 🙂
Piper_Deck
  • June 16, 2022
Came here to upvote this feature request!
Jacob_Morrison
+1 to this! Can’t figure out why we wouldn’t want to build our components like this. I’d love to hear what the Figma team thinks if they don’t plan on including it.
dpoliti
  • July 21, 2022
big plus one! we need this
Troy_Brennan
  • July 28, 2022
+1 +1 +1 I was just trying to figure out what I was doing wrong and turns out it’s not possible! Definitely would prefer this over selecting from loose components on the page.
Steve_Huntington
This would be so so helpful, I’m kind of surprised it wasn’t included with the instance swap update in the first place!
Jean-Marc_Lehwald1
I have several releases within in Figma. And the newest Release should get a new library. But the swap does not work as the instances of the librarys components nested in instances who came from earlier Releases. So if I swap the library in the first release, everythings work fine. Also if I detach my screens from the old Releases and make new components it still does not work at all 👎
  • December 11, 2022
