I’m using a copy of a template and the text inside is editable but the positioning is fixed. How do I move the text elements around to work?
Screenshot 2023-10-19 at 11.00.22 PM
Hey @smithowitz1 ! You are working with a child component, this means that you will be able to edit some things from the component, like text, color, etc. But you cannot change the positions of elemtens, in order to do this you have to edit the parent component or create a variant for this component.
Hope this helps!
@smithowitz1 - To complement on what Martin said essentially select the parent element, double click, and press remove auto layout 🙂
