Hi Windmail,
In not sure if this is the correct answer you are looking for, but would this do the trick for you?
This of course does not work if you want the content in the frame to stay in a fixed direction.
Hi Rasmus Polaszk, Thank you for your reply.
I remember that in the last version of Figma, when switching between landscape and portrait, I can just swap the width and height without changing the Rotation, is this feature deprecated?
Hi @windmail
It has been left out on the new UI, but according to Figma’s designer/advocate it should make a comeback in the interface soon
About the design
“We’re adding library information for components, bringing back frame orientation controls, and making improvements to blend modes. All coming soon.”
https://x.com/_joelmllr/status/1820872135998345719
About the update
“Y’all have been amazing with the feedback on Figma’s new ui. Here’s our first round of updates and ones coming soon.
https://x.com/rogie/status/1820880969223868835
Hi, @Haroll
Thanks for letting me know! That’s great news.
NOTE: If you do end up rotating the frame, please note that adding autolayouts will now act opposite. i.e., adding a horizontal autolayout will behave like a vertical autolayout. this was messing me up until i figured out the reason.
I hate the lack of Portrait/Landscape feature in the new UI. It’s not only creating problems with autolayouts, it also doesn’t allow to add grids to a frame that has been rotated. What a mess
Before update just swap Height with Witdh
In the meantime you can swap back and forth between the new and the old UI using this:
