Why doesn't swap overlay work for this frame?
I create a swap modal while referencing following vide in YouTube.
However, It’s not working…
So, I want to know the reason why the swap overlay doesn’t work.
Here is my created swap modal:
Your Frame 15 > Group 2B > Group 1B > Rectangle 3 has an interaction to “Close Overlay” on click. Remove that and it should work.
Oh!! Thanks!!
I’ve solved this!!
The “closed overlay” was not found because the prototype did not show the “closed overlay” connection. How did you find it?
I just drilled down the layers until I found the interaction. Something was closing the overlay on click so it had to be something within that group of objects.
I understood.
You’ve been very helpful. Thank you so much.
