Why can't I reorder this last variant property in the inspector?
  • January 25, 2023
  • 4 replies
  • 769 views
Arvid
  • 44 replies
I have added a new variant to my component but for some reason I am unable to change the sorting for it. It will stick to the bottom no matter what. Even when I copy the component into a new file it will not let me change the sorting. Is this a bug or is something preventing me from doing this that I might have overlooked?
firefox_nBJxSbC8Vr
Here is a link to the file where I pasted a copy of the component.
Figma – 25 Jan 23
Best answer by tank666
Hey @Arvid, this is because some variants are missing properties. Notice the error in the properties panel. Fix that and then you can reorder that property.
  • 4873 replies
  • January 26, 2023
hassanizhar
It is possible that the variant property in question is a read-only property and cannot be reordered in the inspector.
It’s also possible that the inspector is not set up to allow reordering of that particular property. This could be a limitation of the tool or framework that you are using.
It could also be an issue with the code, in that the property has been set as non-reorderable in the script.
Arvid
  • 44 replies
  • February 1, 2023
thanks, that fixed it!
  • April 21, 2023
Ughh I have the same issue. I can’t rearrange and move the Text over Variants in the Properties list. And there is no error.
What’s the fix???
