Return to instance button was disappeared
Hello. not sure what happened, but the Return to instance button disappeared.
just to clarify my process is:
  1. created a component.
  2. duplicated it
  3. once insitu I realized I want to make changes to the main comp.
  4. click go to the main component
  5. then realize the Return to instance button is not showing up.
would love a shortcut for sure. I could not find any info about the topic either.
A post was merged into an existing topic: The “Return to Instances” option has disappeared
Hi there! Thanks for flagging this, I’ve gone ahead to merge your topic with a similar one. Please continue the conversation here: The “Return to Instances” option has disappeared
For your information, the engineers have worked on this issue, and the fix is now out. Please refresh your browser or the tab for the fix.
If you are still seeing the same issue, please let us know, and we’ll troubleshoot further! Thank you
