Hopefully someone can help me. For the last several days I have been having an issue with one of my components in my shared component library. I have been actively making changes and publishing them to the shared component library to use in a separate Figma file. Both the Library file and the separate file have a blue icon under Assets > Updates for this one component. The grey update button doesn’t work. When I click it nothing happens. The blue “update all” button simply dismisses the window, but the component update notification is still present.
I have tried
deleting and restoring the component
renaming the component
updating other components and publishing all changes to the library
closing and re-opening Figma
restarting my computer
Any thoughts on how to resolve this?
Also, another weird thing I observed… most of the components in the Library file are in the “Local” component list. Why are some listed separately when they are from the same file?
TIA
I’m facing the same problem. Updated MUI library with my own color theme and component styles and published the library, now trying to update those components being used in another file but no luck T-T
Same issue, improved component in the library>Published library> updated component in project file but the component in questions doesn’t update in the file or from the assets panel.
Scratch that, I just realized I had conflicting overrides names which didn’t get flagged. I corrected and all is good and the project files are updated.
The same issue. Found the solution. I created a new file and was moving artboards one by one to it until I got the “update” message again at the new file. That is how I found the broken artboard. The broken component on this page was at the hidden layer, so I unhided all layers with component, then updated library (or you could try “reset all changes”) and the problem gone.
Seems like hidden components have some updating issue.
