I’m using a MacBook Pro. My prototypes run smoothly on my second screen, a Dell monitor, but when switching to the MacBook screen, it turns out so laggy, impossible to present something.
I’ve read similar issues, but haven’t yet found a solution. Removing unused frames won’t do it. It shouldn’t be the problem since it works fine on another screen using the same CPU power, right?
I would recommend you to reach out to Figma support team via support@figma.com or the support request form so engineers could take a closer look at this issue.
Hi everyone. I have the same problem with the prototype. I tried everything, right up to removing all the animations from the prototype - it didn’t help. For some reason, no one from support responds to my topic, although I attached screencasts and a link to the prototype and described the problem in detail. If it is not difficult for you, answer in my topic to draw the attention of support to my problem. This really prevents you from approving the layout with the customer. Thanks. Here is a link to my topic: Prototype is freezing (mobile layout)
Did anyone ever find a solution to this problem? My very lighweight site presentation is so laggy on my 2020 Macbook Pro with the M1 chip, it’s almost unusable in any situation.
Same problem for me, prototype on my beefy MacBook Pro M1 MAX 64 GB RAM + 4TB storage, which should absolutely rip through this is very laggy and unusable. When will Figma release proper support for M1? It’s already been a year and many creative professionals us MacBook pros.
