"While hover" problem with (local) text styles
Hi! Suppose I have a component with variants that make use of local text styles - one without underline (normal) and another with underline (hover). Problem: when exiting hover (in prototype), text style does not reset. But, if I detach text styles, its working!? All other resets work (color etc), except text styles.
Someone else having this problem? I’m working with a starter file which I’ve been using for months and as of today this problem occured :frowning:
Yup. Having the same issue. Set base component with two different text styles. Default=Regular @ 100% Opacity, Hover=Bold @ 50% Opacity. When mouse exits, the color resets but the text style does not reset to regular.
Found out that detaching and reapplying text styles in main component resolves the problem.
That’s pretty hacky but it works. haha
