Hei, I discover interaction between normal text and text with underline not work. One component is normal text the other is with underline. At first the hover effect worked without text input changing. When I changed text in the instance, then interactive effect disappeared.
Hey there,
can you try reloading your prototype and maybe share a file. It works on my end!
ā Niko
Prototype example:
https://www.figma.com/proto/WTHbexy7JtmGuNtxNJGIRZ/Interaktive-components?node-id=1%3A2&viewport=501%2C454%2C0.5&scaling=min-zoom
Hi,
Iām experiencing the same issueā¦
When using a āhoverā interaction, the variant of the component is showing but not the underlining of the text. Is there a solution for this?
Thanks
This is still an issue - 1 year later.
Can this bug be prioritised please?
Hello? Still an issue. Having trouble in my usability testing, because underline on font does not show in prototype for some reason.
Same problem here! Please fix this Figma team
Iām still having issues with this?
I am still having this exact issue, someone help D:
Weāre facing this same issue on link-style CTA components. Whatās weird is that itās only an issue when the hover variant removes the underline. It works fine if the hover effect adds an underline.
Essentially we have a component where:
- The Default state has an underlined text-label
- On-hover, we switch to a variant without the underline and change the text colour
- When we create an instance of this component, and donāt override anything the interaction works as expected
- BUT if we override the label e.g. from āLabelā to āRead moreā the underline is not removed on hover. Whatās weird is the colour still changes but the underline inconceivably sticks around
Whatās even weirder is that if we swap the states (no underline by default, and underline on hover) everything works perfectly as expected.
Wild that this is still a bug more than 3 years later!
