Hi, I’m building a simple component that has a rule line and text underneath it. I first set up the component for the rule line with 3 variants for the different line widths. I then created a second component that includes the nested rule line component with a text box. But for some reason, even though I can select the line variants, the line doesn’t actually change. Have I set this up wrong?
As a side note, I initially set up the line component using a rectangle with different heights and I tried it out with a line instead (second page in below file) and this seemed to work. Does this mean that we can’t use different sized shapes as variants? Thanks!
