One of our designers ran into this problem when we updated all our text styles in our library with a new typeface. Now in most (if not all cases) the new text styles aren’t getting applied automatically.
Now you either have to manually select the text and the element updates itself or you have to choose another text style and then re-select the right one (that was previously applied).
The text elements still have the correct text style applied, but they aren’t updated.
What could be the reason for such a behaviour?
It would be a pain to go through our file and manually select each text layer to update/refresh the style.
I heard about this issue from a different user. You may want to record a video and send it along with other details and links to Figma support team via the bug report form.
Personally I haven’t encountered the problem again, as it seems to require specific circumstances. As I wrote in my last reply - the recomputing of the text layer fixes the issue.
Had the same Issue and was indeed using Batch Styler Plugin. Could be the cause.
Figma was not showing any changes made to the styles (Line Height). Fixed it by adding a strikethrough, doing a publish then removing it again with another publish. All done by the native interface. Then it updated and recognized the line height change as well.
The users above were able to resolve their issues using various methods as mentioned in the thread. If their solutions don’t work for you, please feel free to submit a bug report with more details to our support team directly via the form here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
I’ve found the same issue still in May 2023. The only thing that I’ve found to work is clicking in to each text instance as if to type and it overrides the old styling.
I have a similar case where when I try to change a word in a sentence, the word doesn’t change for other users. When I reload the page, the word I just added disappears. Then it reappears when I click the text component. Unfortunately, I don’t have a screen recording for this…
