yes you can’t have 2 action on the same input since figma won’t know which one to do.
Depending on what you want… if it’s just having the image selected on the next page then I would recommend you to just have the image in a selected state on the other frame.
the other way around would be to have only 1 frame and use only the switch variant.
if you want to be able to select multiple images
I would strongly encourage you to create a component with a selected state variant that swap on tap.
then duplicating and overriding the image inside each instance
