Hi everyone,
I’ve created a switch component with a label. The label has ‘Default’ vars assigned to the On and Off state respectively (open the Local Var collection).
I hoped to change the assigned var of the label to the ‘On’ and ‘Off’ vars defined in the ‘Changed’ var group (as defined in the Local Var collection) on the instances–you see at the bottom under “Uses ‘Changed’ label var”.
All works in the Editor when I toggle the on/off state in the properties panel.
However, in the Prototype view clicking on the “Changed” instances it reverts to the “Base/With Label” component var i.e. to “Off” or “On”.
Is this a bug of the Prototype View or am I missing something? I tried restarting the file, switching back and for to different pages to reset the prototype view, but nothing helps.
Bug Report_ String vars not switching.fig (132.0 KB)
