I think I broke my figma install
I uninstalled it and when I tried a fresh install from the downloader on the site it keeps throwing this error. thanks in advance!
2021-08-25 20:45:37> Program: Starting Squirrel Updater: --install .
2021-08-25 20:45:37> Program: Starting install, writing to C:\Users\Mark\AppData\Local\SquirrelTemp
2021-08-25 20:45:37> Program: About to install to: C:\Users\Mark\AppData\Local\Figma
2021-08-25 20:45:37> Program: Install path C:\Users\Mark\AppData\Local\Figma already exists, burning it to the ground
2021-08-25 20:45:38> IEnableLogger: Failed to remove existing directory on full install, is the app still running???: System.UnauthorizedAccessException: Access to the path 'C:\Users\Mark\AppData\Local\Figma\app-101.6.0\chrome_100_percent_IObitDel.pak' is denied.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.File.InternalDelete(String path, Boolean checkHost)
   at System.IO.File.Delete(String path)
   at Squirrel.Utility.<>c.<DeleteDirectory>b__19_0(String file)
   at Squirrel.Utility.<>c__DisplayClass12_1`1.<ForEachAsync>b__1()
   at System.Threading.Tasks.Task.InnerInvoke()
   at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at Squirrel.Utility.<>c__DisplayClass13_1`1.<<ForEachAsync>b__1>d.MoveNext()
   at Squirrel.Utility.<DeleteDirectory>d__19.MoveNext()
   at Squirrel.Utility.<>c.<<DeleteDirectory>b__19_1>d.MoveNext()
   at Squirrel.Utility.<LogIfThrows>d__42.MoveNext()
2021-08-25 20:45:38> Unhandled exception: System.AggregateException: One or more errors occurred. ---> System.UnauthorizedAccessException: Access to the path 'C:\Users\Mark\AppData\Local\Figma\app-101.6.0\chrome_100_percent_IObitDel.pak' is denied.
   at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
   at Squirrel.Update.Program.<Install>d__4.MoveNext()
   --- End of inner exception stack trace ---
   at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
   at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
   at System.Threading.Tasks.Task.Wait()
   at Squirrel.Update.Program.executeCommandLine(String[] args)
   at Squirrel.Update.Program.main(String[] args)
---> (Inner Exception #0) System.UnauthorizedAccessException: Access to the path 'C:\Users\Mark\AppData\Local\Figma\app-101.6.0\chrome_100_percent_IObitDel.pak' is denied.
   at Squirrel.Update.Program.<Install>d__4.MoveNext()<---
A post was merged into an existing topic: Problem with the desktop version (Windows)
