Is the option to copy/override an image in an instance removed? Worked before using short coammand “Command + shift + c”, “command + shift + v”
Its way more time consuming changing images using finder
command + v
Perhaps you mixed up the shortcut. To copy properties use Cmd+Opt+C.
Thanks a lot! Perhaps I did. Remember it was different before, maybe getting old
