I sometimes use FigJam to make shareable slides or documents. When doing this, I wish there was an easy way to export each of these files separately in one go (instead of as one file) - and more importantly, that I didn’t have to manually re-name each file from the FigJam board’s name to the section’s name.
Hey @Tanya_McCorkle, thank you this is a great feedback! I’ll forward this internally to the teams for consideration. I’ve seen that community members suggested a plugin Super PDF - that can merge and combine frames, sections etc in Figma and FigJam into single PDF files.
And I do understand that a native solution better here, but I hope the plugin will help you out in the meantime. Also, feel free to upvote your post, this helps us roadmap future updates.
Please let me know if you have any further questions.
@Gayani_S thank you for recommending Super PDF. @Tanya_McCorkle you can do exports from FigJam with Super PDF and soon you will have the opportunity to use the name of sections as the file name. I hope this helps to make your workflow faster. Is there anything else that will make your workflow easier?
