Use CSS var names instead of hex codes for colors in inspect code view
Select a component, then click on the Inspect pane and look at the generated code. It will contain entries like:
/* gray-262_20/gray-262_20-33 */
background: #494C65;
Developers won’t use this code. They will use the CSS variable names as defined under Design – Color Styles.
Desired output:
background: var(--gray-262_20-33);
Please fix. Thanks.
