I have a design file with multiple frames - some are more complete than others. I want to share just one frame for review with a client. I don’t want them to see the other frames in the design just yet. Is there a way to share just one frame for review?
Hi Hugo,
I have the same problem, still searching for a solution I come from a sketch-InVision workflow, sharing single screens was perfectly easy. Will let you know if I find any helpful info on this.
@Motele I think I found a solution. If you go into prototype mode. Make the frame you want to show a flow (a flow with just one frame). Then present that flow and click the share prototype button (top right). It worked for me, let me know how you get on
@Hugo_Evans Thanks, that is a great workaround, it is useful to present a design to a product owner. There is still the problem of sharing one frame and share this one Frame in Dev Mode for the developers.
In Invision you have an Inspect Mode for the dev handoff. You create a link for one Frame/Artboard and share it with PO or Dev. Depending on what you need you can either just view the design (as a PO) or switch to DevMode (for Dev).
I am pretty new to Figma so maybe the all over workflow for Design-2-Dev is different.
that’s a great solution if they can’t use Figma. but if they know how to use Figma, they will open your whole file. instead, you can create a new file specifically for the frames you want to share without worrying that they will see your other frames.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
