When I set the fill of a frame/shape to an image, it would be really good if i could set the image to fit, and then choose where to place it in the frame (top, bottom, left, right).
Yeah like in web you can set your image as Fill and then select which corner you would like the image to scale/expand from. Yes, this will make things much easier. I know you can use the Crop method but after you crop your image if you decided to scale your image from one side it will stretch/distort the image which is not helpful, so if I use the Crop method I can only scale with proportions Or scale up and then adjust my crop. You’ve got my upvote my friend
