As the title says a dropdown component i made stop working properly after i nest it in another component. Anyone had similar issues and knows the solution?
Examples below:
Examples below:
It looks like the top instance has the height set to hug but the bottom one has the heigh set to fixed.
Thanks for your reply.
I don’t think that’s it. It’s two instances copied from the same component so they should be identical.
Just tested it out. If i put the dropdown component onto a frame it works just fine. If i put into another component even if the component is just a grey box it breaks.
Glad you found a solution!
If you look at the properties of the instance and not the main component they could also be causing this issue. In terms of hug/fill/fixed. sometimes they get changed by accidentally double clicking the edges.
Sadly i am still dealing with the issue and havent found a solution.
What i meant was that i replicated the issue by throwing the dropdown component into another component (a grey box) and the dropdown still is not expanding correctly.
Could you share a link to an example file?
Just figured it out.
Some of the elements in my component didnt have constraints configured.
I set all of them to constraint left/top and now it works as intended!
