I can’t undo a component or un-component assets if that’s understandable, this is quite affecting work process. Can’t just I detach an asset from being a component.
The easiest way I found to solve this is to Duplicate the component and then Detach the component from the parent component. Then you can delete the parent component if you choose.
I am working with complex systems.
