Can I auto-layout a component instance?
Hi, I’m trying to auto-layout a text that is an instance, but
it doesn’t auto-layout if I don’t detach instance, is there an option?
Screen Shot 2022-02-14 at 16.32.39
You have a width that is more than likely set to fixed instead of Hug Contents. See sample for one that works for me. Figma
@zachs
uoooh thank you! with these examples it helps me better understand how to compose the layers so that it works well.
Another question I have is, how would you apply to be able to do auto-layout with a custom vector shape?
Currently it won’t let me, is it the same problem?
See my same Figma as linked above. Easiest way I know is you have to trick it by putting in a small triangle that is the same color as the background darker blue. Also needs more nested auto layouts but it’s there.
