After rotating the frame, the layout grid is not being applied...
After rotating the frame, the layout grid is not being applied. Any one facing this same issue?
Hi @CreativePunk, Thank you for bringing this to our attention!
I’ve done some testing on my end and noticed the same behavior you mentioned. Unfortunately, this is a current limitation. To display layout grids correctly, the rotation needs to be set to 0º.
For more details, you can take a look at this Help Center article: Create layout grids with grids, columns, and rows
However, your suggestion sounds like a valuable feature request. I’ve seen similar ideas from others here, so I’ll go ahead and add yours into the post to give it the visibility it deserves.
Thanks again for getting in touch with us!
A post was merged into an existing topic: Layout Grids not showing on frame rotation
