Ability to Control Frame width of Instances
The frame width of instances cant be controlled manually, and even if I create multiple variants with different frame widths, then by changing variants also I can’t change the width of an Instance. If this is possible making a table with a minimum component is possible, would love to hear about the workaround If any is available. Will be very helpful if this can be done.
Thank You
