Karsten_Muller1
Jan 28, 2022 3:29 PM UTC
Scroll-to action in overlays
As written in the documentation (Prototype interactions and animations) the destination of a Scroll to action can only be an element of the same top-level frame. But with this limitation it is impossible to prototype a common navigation pattern.
On one-pagers there are often floating menu for intrapage links. E.g you have an hamburger icon that opens a menu overlay from where you can scroll to a specific page section. This can’t be realized with an Figma overlay because of the restrictions mentioned above.
There is a workaround, but it seems that it only works because of a bug: You can set the menu overlay as an child of the top-level frame of the one-pager, define the Scroll-to actions and then move the menu outside the frame (as an separate top-level layer) to show it later as an overlay. By doing this all the Scroll-to actions still work, but when you change an action the target will be rested and the navigation is broken.
Working Example
Maybe you can remove the restrictions that the destination of a Scroll-to action have to be on the same top-level frame for frames that are placed as an overlay.
Feb 27, 2022 3:29 PM UTC
Roeloff_van_Zyl
Mar 29, 2022 3:51 PM UTC
Hi, is it possible to apply a "scroll to" interaction from an Overlay to a section on the main page/frame?
Let me try to explain:
So, when the user hovers over an item, a pop-up overlay should appear. On this said overlay the user should be able to click on a button and then be anchored (scrolled) down to a specific point on the same page.
When I want to add a "scroll to" interaction to the button located in the overlay the only layers available for selection are the ones of the overlay, so I cannot select a point on the main page/frame
Am I missing a step or does this not exist?
TL;DR: How to apply an anchor interaction from an Overlay
Apr 19, 2024 9:23 PM UTC
I also want to be able to do this! But, because the overlay is its own frame, I don’t think I can.
Apr 23, 2024 1:28 AM UTC
Thank for the post.
Unfortunately, it is unavailable at the moment. As the article says, If you add Scroll to using the Interactions section of the Prototyping panel, you can only pick direct children of scrollable frames. To pick any object within the top-level frame, drag out a noodle and link it to the object you want to set as the destination.
There is an existing feature request thread, so let me merge into it.
Thanks!
Toku
Edwin Ties
Jan 19, 2025 7:43 PM UTC
I wanted to do this in my project too but couldnt make it work :(
Mait_Luidalepp
Feb 10, 2025 5:32 PM UTC
I find it hard to believe that Figma cannot still simulate dropdown navigation.
Is this real?
Karsten_Muller1
Feb 26, 2025 9:13 AM UTC
Is this real?
This article is from 3 years ago. In the meantime, you can build a dropdown menu using components with variants. Just search for "figma dropdown menu with variants" on YouTube to find some tutorials.
EmberN
May 12, 2025 5:15 PM UTC
i also need this for menu overlays pls. need it to scroll to a page right after clicking on the overlay menu on mobile.
Kebin
Aug 5, 2025 5:19 PM UTC
These needs to be a thing. I’m dealing with the same problem as everyone else here. Being able to scroll the main page from a overlay would be great to have.
Ben_Browning1
Oct 2, 2025 9:57 AM UTC
Just ran onto this today. I have an alert modal that appears as an overlay on the screen and wanted to have a prototype action that closed the modal overlay and scrolled to a section on the screen but wasn’t able to do this.
