Ze_Zorzan
Mar 26, 2021 5:37 PM UTC
Why icon instances are not preserving overrides only when I'm consuming them from a library?
So, I’ve created some icons using variants. It looks like this:
(How the layers are organized, the Icon layer is an Union)
(Properties of each icon)
Then, I created a button component with different sizes and states using a placeholder icon:
When I create an instance of the button in the same file (local component), I can swap the icon in the button and it preserves the icon properties:
(In this case, the properties were: Small, Filled)
But, when I use the same component in another file (now consuming from the original file, as a library), I can’t do the same:
(The icon properties got resetted)
Am I doing something wrong? Why the different behaviors when instancing inside the file and outside of it?
dennsi
Jun 8, 2022 2:46 PM UTC
Can you provide an example file to check this out in detail?
Alborz_Heydaryan1
Jun 8, 2022 8:41 PM UTC
I have a huge problem with this. The icons I put in my buttons can have inconsistent line thickness and colour. Tried a few different methods to fix with mixed results. but nothing works 100% so far. I wish it just tool all the properties from the component and applied it to the button sub-component by default.
zan2
Nov 12, 2024 4:28 PM UTC
Did you ever find a fix for this? Sounds like I’m having the same issue - Instance swapped icons don't preserve across variants?
