orkhanjafarovr
Nov 24, 2021 10:53 AM UTC
How to find detached nodes?
Is there way to find all detached nodes in the file ?
Power Member
Nov 24, 2021 11:10 AM UTC
No, detached instances become regular frames, they don’t contain any info about their previous state of being instances.
The only thing that comes to mind is you can use version history for that, but if instance creation and detachment happened within one version, then it won’t be possible to detect.
HonzaTmnProductboard
Nov 29, 2021 12:05 PM UTC
There was a nice tip from Uber’s team on the last Config – adding Signature pixel to each component, that stays there also if the component is detached. Check it here. It could help for what you want to achieve.
orkhanjafarovr
Dec 1, 2021 5:10 PM UTC
That’s exactly how we do this. But I was looking for something built-in for the components without any trackers inside. Thank you!
Daniel_Golden1
Dec 8, 2021 11:12 AM UTC
Is there anywhere to read up on how how Uber did this? I’m trying to implement the same thing for our our design system at New Relic.
orkhanjafarovr
Dec 8, 2021 11:29 AM UTC
It’s about keeping a node with specific name, when you can scan these nodes and check if they are in instance or not to mark it as detached.
Check youtube video " Using Figma to go beyond Figma - Dylan Babbs, Vietanh Nguyen (Config 2021)" (can’t use links in the forum 😢)
We have a similar way, but a bit more advanced
Daniel_Golden1
Dec 8, 2021 11:38 AM UTC
I’ve been watching that video on repeat this morning trying to discern how they did it. As far as I can tell, you’d need to be able to access and get the contents of every file in the organization to make this work, but the Figma only allow you to access files that you have the fileID for, right? I’m hoping I’m incorrect about that, but that’s the best I can see.
Has your team written up anything about how you pull this off?
Edit: I think I got it. You get all files of a project by providing the team_id then you get all of the files in that project.
Daniel_Golden
Jan 19, 2022 10:22 AM UTC
Have you run into the issue where the file your scanning for detached components is too big and your API request times out? If so, how have you gotten around this?
Amogh_Srivastava
Sep 29, 2024 6:05 AM UTC
I can see that Figma shows that an instance was detached and it can also be traced back by going to main component
Even in analytics the components leave some breadcrumbs behind by showing detached.
How can we use this to scan a frame/page/files for detached components? 🤔
Power Member
Sep 29, 2024 2:16 PM UTC
I made a plugin that can help you find detached instances:
https://dominate.design/detached
It’s free to use to find them but if you wish to reattach them using smart Master plugin algorithms it’s paid.
Bala_Sivagnanam
Oct 1, 2024 11:01 AM UTC
Is there a way to do this instead of tracking hidden pixels? or any other alternatives?
