Hello, I’ve stumbled upon this bug ever since the variables feature was introduced to Figma.
I use a LA-MX keyboard layout and, for some reason, when I press the “+” key to type in a formula in any value field (such as width, height, padding, radius, etc.), the variables selector appears instead. This makes it impossible for me to do simple addition in those fields.
Hopefully there’s an easy fix or workaround for this. Any help would be appreciated!
Hi @Alejandro_Oliva we recently released a fix for this issue where with some keyboards you were unable to use the “+” key for formula expressions. Are you still seeing the issue after reloading?
I hadn’t noticed there was an update! I can confirm the issue is fixed. Thanks for the help! 😃
