Page 1 / 1
This executable file (Update.exe) is probably no longer in this directory. Try to open the folder along this path: C:\Users\Marina\AppData\Local\Figma
I opened the folder, this file is there. When I try to delete it, I get the error “this item could not be found”
Try uninstalling using the command prompt (as described above) or try this method:
Everything worked out! Thank you!!!
Thank You! It really works!
