In some cases when I outline my words (using the Outline Stroke tool), the output of the “Copy as SVG” function is a single path code, while other times it creates a path for each letter. What is the deciding factor for the program to create singular or more paths in this situation?
Image 1: The two vector elements used in the 2nd image
Image 2: (above) SVG Code with one path; (below) SVG Code with multiple paths
