I use a component which is from existing component library. By default, the color text is Black. Once I import the components from that library, the black color doesn’t reflected on text.
Hello @_FPT_Rose_Le_Thuy_Diem Thanks for contacting us! Please provide more information so we can better understand the problem.
Could you share screenshots of the Full Figma screen(including left and right panel) and the steps you followed to import the component into your design file? Also, has the main component been published?
To use component from published library, you can add the library to your design file and insert an instance from the asset panel, or you can copy and paste the instance.
We look forward to hearing from you. If anyone in our community has any ideas or suggestions, please share them!
Thanks again!
