Can you search text by formatting?
Is it possible to search by formatting like in Indesign?
For example, can I search for all text using the font size of 24 pt?
Thanks for reaching out. Unfortunately, I’m not aware of the specific search feature, but you can select all texts with the same text properties by using quick actions. If you have a text with specific properties, please try following.
  1. Select the text with the properties you want to search.
  2. Use the keyboard shortcut to call quick actions:
    Mac: ⌘ Command / or ⌘ Command P
    Windows: Control + / or Control + P
  3. Type your search in the field - “Select all with …”. Figma will show results that match your term as soon as you start typing.
  4. Navigate results by pressing ↑ or ↓ on your keyboard.
  5. Press Return or Enter to perform the action.
    Here is the help center article: https://help.figma.com/hc/en-us/articles/360040328653-Use-shortcuts-and-quick-actions#Quick_actions
It might not be the best solution for you, but quick actions is helpful. I hope it helps a little bit.
