Who else is trying to find where the corner radius is in Figma Slides?
The problem is sometimes it’s there, but sometimes not…
It is definitely a bug, I had to quit Figma and re-open it in order to see the corner-radius section. It was completely missing.
Hey All, thanks for flagging this!
We’ll pass this onto the Slides team to investigate. In the meantime, glad to hear that quitting/refreshing should fix temporarily.
Thanks for the swift response!
FYI I’m having the same bug with other functionalities too: for example, some minutes ago I couldn’t see the “layout grid” panel to adjust the guides, I tried switching back to Slides mode and then back again to Design mode to see the panel again. It also happened with the “Appearance” panel this morning, I couldn’t see it and regulate opacity, then closing and opening Figma again did the trick.
You’re welcome, @EmilyMoze!
Sorry to hear this is happening with other functionalities as well. I’ll pass this onto the team to try to repro and fix.
I have the same issue
I closed app and open again. But it didn’t work.
Thanks for chiming in, @nanacodesign!
I’ll pass along this feedback to the team that closing and re-opening Figma is no longer helping the issue.
Also cant find the corner radius. And reopen the app doesent change anything getting mad.
Sorry for the frustration, @Caio_Zafalon!
I’m following up with the team to hopefully get an update on their investigation.
Just had it happen to me as well.
Also had this happen with layout grid. It just disappears and randomly appears after 5 refreshes.
Oh damn, just noticed my layout grid was gone too.
Hey All, thanks for your patience and understanding!
The team confirmed that this bug was caused by conflicting coding logic that caused a different permutation of panels to compete with each other to be visible, affecting not only corner radius but also the layout grid panel.
Our team has developed a fix that will start being deployed later today through the end of the day tomorrow - stay tuned!
