ottovortici
Feb 12, 2024 9:01 AM UTC
Would be nice to be able to create the equivalent of Classes on Figma
The use case is very simple:
Instead of creating a component for “bundles of characteristics”, it would be nice to create classes that you could use to style elements.
The most common example would be within cards.
You would create a class that includes these styles for the card :
  • Shadow
  • Border radius
  • Background color
    And you would use this class to style every card component.
The problem now is that you can:
  • Either create a card component with a slot, which is not always ideal because you have to make sure that the content always behaves as wanted within the card
  • Style with variables or styles each element of the card everytime
Classes would really make life of designers easier, and make it more dev friendly.
Matt_Meeks
Feb 12, 2024 10:50 PM UTC
This seems like it should have been a feature in the very first release of Figma, and would make a huge difference in my productivity
Feb 14, 2024 3:05 AM UTC
Hi there, Appreciate you sharing your thoughts on create classes!
I understand how much this will help you all and this might be handy for other community members as well.
I have shared your ideas with our internal team for future consideration!
ottovortici
Feb 14, 2024 9:50 AM UTC
Thanks @Junko3 for your reply.
Hope it gets some attention
Calvin_Kuo
May 22, 2025 1:30 PM UTC
Bumping this.
Also to mention other use-case: to better align with our code.
We are trying to maintain consistency by using classes in code, but there is no counterpart in Figma. Right now designers have to remember something like “this border goes with this background”, and there is a lot of rooms for human errors.
Johnson_Ryan
May 22, 2025 4:18 PM UTC
This seems like it could be an extension of the existing Styles functionality as “Layer” styles.  You can already copy/paste properties on a layer, why not take it a step further and save properties as a layer style?
  1. Layer styles would be composite styles that apply multiple properties of a layer
    • (i.e., almost everything you can adjust in the right panel).
  2. Layer styles likely need to be scoped to the specific layer type, so that they don’t contain properties that aren’t applicable to the layer type.
  3. Layer styles should allow a style author to configure the code output, similar to functionality in variables.
    • Web: CSS classes
    • Android: ??? (I’m not familar with platform)
    • iOS: ??? (I’m not familar with platform)
