Eli
May 16, 2024 2:10 PM UTC
Stroke offset
It would be very useful to have the ability to offset a stroke. For instance, in the case of the focus state for buttons and other components. Currently, there is a workaround, but it is not very convenient as it requires us to manage shadow and transparent stroke. This is especially inconvenient for a large library of components and complicates developer handoff.
Pavel_Kiselev
Power Member
May 17, 2024 6:53 AM UTC
You can try design component instead
Figma – 17 May 24
Place it on top of your focusable element. There two rectangles inside to control radii, offset size and outline width. And it’s easy to bound colors to the outline
Eli
EliAuthor
May 17, 2024 12:19 PM UTC
I understand your point. The problem isn’t about creating an offset outline around a rectangular shape. What we really need is an efficient way to handle focus states for a large library of components. Drawing shapes around each UI component manually is possible but not a productive way to manage libraries. Just think about having to adjust the stroke thickness across the entire library of 100s of components in your design system.
What we need is a property that accepts variables and can be applied to the parent container of a component.
Pavlo_Kiselov
May 17, 2024 12:27 PM UTC
Nah, you create single component, aka focus ring, and incorporate it whenever you need it. Separate component does wonders. Here are some examples
Master component
Base input
Inset labels input
And many others. Like buttons, nav elements etc. Mine on advanced side of things, I use component swap to control radii with a single prop without going down layers.
Once you have them all over focusable components, it’s easy to adjust the style as it is a single component. I would nevet bother adjusting stroke width for 1000 layers, there are design components for that.
Pavlo_Kiselov
May 17, 2024 12:34 PM UTC
If you are curious, have a read - Making of true multi-brand design system | by Pavel Kiselev | UX Collective
I expand in great detail on the issue
Eli
EliAuthor
May 17, 2024 1:09 PM UTC
This is clear. You have to maintain a specific focus shape for each component type, such as one for a button and another for a checkbox. This requires a lot of effort, and if you need to make any changes, you have to update a significant number of shapes.
Please explain how this is superior to my example, where one must manage two existing properties: 0.01% transparency and a shadow, which can be applied to a component of any shape or size?
The second question is, how is that better than having stroke offset parameters?
Pavlo_Kiselov
May 17, 2024 1:37 PM UTC
Easy. First it is some magic knowledge. I have to know about 0.01% transparent border as an offset and it is manual labor to apply it. Second I need to pick proper shadow style. Now, if by some reason you decide to change the offset value or try different style, you screwed. It is the same reason we use design components for buttons, forms etc, it give control over visuals and saves effort to maintain and evolve.
It’s not better, I just talking real. Stroke offset may never happen, design component is timeless
Good luck mate, I am not trying to sell you anything, just sharing
Eli
EliAuthor
May 17, 2024 2:30 PM UTC
By definition, managing object properties is easier than managing shapes. The stroke fill can be variable, but currently, the stroke width cannot be variable. Hopefully, this will change based on the current trend of tokenization. The shadow can be a style, so you don’t need to worry about the component’s shape or size. Although not ideal, is still easier and more manageable than maintaining individual shapes.
It’s not better, I just talking real. Stroke offset may never happen, design component is timeless.
You meant talking current, I suppose. The shapes workaround is one way of doing it. It wouldn’t be my first choice, but I’m happy it works for you.
Julian_Castano1
Apr 3, 2025 2:18 PM UTC
Why are you both here throwing nice tricks on how to make a CSS property emulated in Figma?
Figma should give us the option for ‘stroke-offset’ and be done with it. End of story.
Matze
May 12, 2025 1:11 PM UTC
100 % agree, I’m currently writing a script to automatically migrate variables and styles from Figma to Tailwind Config and those hacks to create an outline make it impossible to have it converted.
wahid
Oct 31, 2025 2:40 AM UTC
What i do is put it inside another auto layout frame and put a stroke on that with little padding around the sides
