Luke_Caddy
May 11, 2021 4:35 PM UTC
Shape Builder Tool
The lack of a Shape Builder Tool (like in Adobe Illustrator) is surprising. This is an essential tool that I use on every project in Illustrator. I have used the Boolean Groups, but they don’t fill the use of a Shape Builder Tool. A SBT allows me to trim the edges of overhanging shapes, which I commonly do when designing.
Sam_Hamilton
May 20, 2021 7:58 PM UTC
  1. I’ve found it to be very unintuitive to create quick unique shapes in Figma. They have a set of predefined masking buttons, but nothing as flexible and easy to use as Illustrator’s Shape Builder.
  2. In Illustrator, there is a tool that allows you to combine or subtract space from overlapping shapes in order to build new shapes quickly. This makes creating icons extremely simple and fast. In Figma, every time I have to create a unique shape, I find myself fumbling through the (in my opinion obtuse) masking buttons to try to figure out how to get it to create the shape I need, and then it seems to retain the original shapes behind the mask, rather than creating new paths and a new bounding box for the new shape. It’s annoying.
  3. Does anyone else miss using the Shape Builder tool, or struggle with the current masking buttons?
Figma_Bot
Aug 22, 2021 10:34 AM UTC
This tool is the reason why I still use Illustrator beside Figma, to do things like drawing icons,… It doesn’t feel so freedom to doing vectors in Figma. The “Shape Builder Tool” of Illustrator is so good, makes you feel you can create any shapes you want. I like “Vector networks” feature of Figma but it’s just not that good.
Denin_Paul
Jan 24, 2022 5:26 PM UTC
Shape Builder for Figma 🚀 🚀
Andrew_Designer
Feb 7, 2022 3:40 PM UTC
The absence of this tool simply forces you to work in illustrator on building anything, more complicated than a primitive, and then import this vector into a figma.
If it wasn’t for the pretty visuals and the “blur background” effect, I would never have even opened Figma.
Adnan_Haj_Ali
Feb 11, 2022 9:31 AM UTC
we need this tool to move totally from illustrator!
maksimpetshak
Jun 28, 2022 5:41 PM UTC
Присоединяюсь! И правда, shape builder tool — ОООЧЕНЬ важный инструмент и почему его ещё нет в Figma, для меня удивление, грусть и печаль… Сделайте его пожалуйста в ближайшем обновлении!
Rei_Supercatt
Dec 31, 2022 5:00 PM UTC
I wish there was an easier way to add/subtract shapes together similar to Illustrator’s Shape builder tool. It would especially be useful for when you’re working with more than just two shapes. The Boolean tools are pretty limiting.
helpx.adobe.com
Currently, I would have to merge the shapes (command+e) and then individually edit the vector paths, which is pretty slow.
Feb 2, 2023 6:27 PM UTC
This is absolutely the main reason why we are not committed to Figma and most likely won’t choose it.
Dogukan_Yazici
May 13, 2023 12:03 AM UTC
Still waiting…
zoltanlazar_unas
May 15, 2023 7:16 AM UTC
Seriously, implementing a shape building would make Illustrator obsolete.
