Brooke_White
Jun 4, 2024 6:23 AM UTC
Re-order auto-layout without detaching
Would be great if there was a way to be able to change the sort/order in which auto layout components are shown, without having to detach or redo all the work to edit the components.
For example:
eg. using a table or list component, and being able to move row 3 to be row 4.
Current native experiences forces you to either:
  1. Detach the component (not ideal) and resort
  2. Redo all the content for both rows 3 + 4
Neither of these are ideal from a system or efficiency perspective.
Jun 5, 2024 4:02 PM UTC
Thanks for the feedback, @Brooke_White!
We’ll pass this onto our team for future consideration.
Desiree_Dahlson
Jun 27, 2024 5:37 PM UTC
THIS. Re-doing the work or being forced to detach is my biggest headache of any of Figma’s limitations. It causes so much work to be wasted. This and similar auto-layout changes to components has been requested by users multiple times over the years, a quick Google search will pull up multiple other related posts in the forum.
Omar6
Sep 19, 2024 11:12 AM UTC
it is super helpful for multilingual design systems, where text order can switch between rtl and ltr.
Mikaela V.
Oct 9, 2025 11:00 PM UTC
I cannot upvote this enough, say for example I have a dropdown menu component, many of our platform’s options menus share similar options e.g.
Most of the main feature menus have: Overview, Add [Insert feature name], Statistics, Reporting, Utilities, Settings. Then most of our sub feature menus have: Add [Insert object name], Edit [Insert object name],  Delete [Insert object name], etc.
The issue is there are always options in the menu between these common ones based on the other options that are individual to a feature/sub-feature, and the total number of options may vary.
If I were to detach the component to get around this, then I would lose the components state variables when I am using it e.g. being able to toggle between whether or not it is enabled, hovered, selected etc. for my wireframes and prototypes. I could just add placeholder options in the middle of the main shared ones and hide these when I don’t need them but its messy and inflexible. I also don’t want to have to create a dedicated component for each feature and sub-feature dropdown we have as that defeats the purpose of creating re-usable components…
That is just one example of when I encounter this issue but I also encounter it with other use-cases. Surely we can’t be the only users frustrated by this.
Bree1
Dec 3, 2025 11:34 PM UTC
This pleaseeeee!! How is everyone working around this with grid layouts, I want my grid of items to be a component so that I can change it from 3-col to 2-col etc but then I cannot change the order of the grid items without detaching
