Luke-Itineris
Nov 13, 2023 11:53 AM UTC
Quick copy hex
It would be great to have a quick way to copy the hex codes of the library colours. At the moment it’s three steps (click the colour > filter icon > copy hex code.
Be great if it could be one click, especially with having to check colours for accessibility regularly.
Haroll
Figma Ambassador
Figma Ambassador
Nov 13, 2023 1:35 PM UTC
Hi @Luke-Itineris
Looks like you are suggesting a new feature, maybe create a new topic in the “Share an idea” category.
Meanwhile when you have an item selected and you want to know its hexa you can hit Shift+D to toggle the dev view. On the right panel at the top bottom your will find the color and its hexa
Figma’s Forum Ambassador
Nov 13, 2023 1:44 PM UTC
Hi all! Thanks all for your feedback. As @Haroll said, I’ll go ahead and switch this topic category from “Ask to the community” to “Share an Idea” so others in the community can vote up for this idea. Thanks!
Luke-Itineris
Nov 13, 2023 4:17 PM UTC
It would be super handy to copy the hex code of a colour in one click. While using a library, in order to copy a hex code to see if it’s accessible I have to
  1. Click the colour
  2. Click the filter/colour inside the panel
  3. Realise I can’t copy the hex
  4. Detach the colour
  5. Copy hex
  6. Undo undo!!
I realise you have a dev mode, great, but this would cater for the designers who need hex codes quickly, rather than doing the above. Here’s a possible solution. Pasteboard - Uploaded Image
JB-C
Mar 25, 2025 4:51 PM UTC
Yes please !
Plus why would you disable copy/pasting the hex color ?
Ok you can’t edit it there, but why prevent copying the value ?
But yeah please allow us to quick copy directly from the color panel.
This could be done by adding an entry to the context menu (right click)
Ulrich W B
Sep 29, 2025 4:32 PM UTC
Install this app:
https://apps.microsoft.com/detail/9MZF6LNP5RV5?hl=neutral&gl=DK&ocid=pdpshare
It makes it easy to copy the HEX code anywhere - also in Figma :)
Bendik_Ramm
Oct 4, 2025 2:11 PM UTC
You can copy HEX codes using the eyedropper tool!
  1. Open the color panel by clicking on any object with a flat color (not a style or variable) and set the color mode to HEX and close the panel.
  2. Now any color you sample with the eyedropper will be copied as a HEX code to your clipboard.
