vsathishkumar
Jul 8, 2022 6:34 AM UTC
Option to duplicate/copy styles, not just cut them
If there is an option to duplicate the Text Styles / Color Styles folder then it makes it easy when creating design systems. Attached is a screenshot of the idea.
Antoine
Apr 5, 2023 9:48 AM UTC
Beware of that workaround if you already have published styles. It has broken a lot of my applied styles in other files (swapping them for the duplicate)
Nomad_Bakr
Apr 25, 2023 1:43 PM UTC
Even better if we have styles/design tokens code editor.
Nomad_Bakr
Apr 25, 2023 2:00 PM UTC
There is a workaround that actually works:
1- Cut the styles you want duplicate
2- Undo so you have your styles back (now the styles and folder structure are copied to your clipboard)
3- Paste the copied styles into a new Figma file then save the file
4- Close both files
5- Open both files again
6- Now you can edit the styles in the new file then cut and paste them into the original file
7- DONE!
ThomasHallgren
May 18, 2023 7:57 PM UTC
Absolutely need this feature.
Jul 21, 2023 10:18 AM UTC
This would be great. The suggested place in the UX is perfect as well. Lot’s of space there.
Julio_Mayorga_Ubiria
Aug 3, 2023 2:19 AM UTC
you the man Adrian! thx 🫶
Yagiz1
Aug 24, 2023 1:07 PM UTC
The following is even simpler:
  1. Duplicate the file
  2. Rename the styles in the duplicate file
  3. Cut styles from duplicate file and paste in the original file
  4. Delete duplicate file
Jonas1
Oct 25, 2023 8:20 AM UTC
There must be some insanely complicated technical reason for not being able to copy or duplicate a style inside Figma.
I use Design System Organizer plugin for the purpose.
Leonardo_Falaschini
Oct 26, 2023 11:51 AM UTC
Yet another important feature that Figma has left unattended.
Nov 8, 2023 10:38 AM UTC
It is a basic necessity, add a duplicate button and it will save us so much time.
