Sep 13, 2023 3:09 PM UTC
Modal to inherit the mode of the frame it appear in
Make a modal inherit the mode of the frame it appear in.
Use case: I am creating a prototype using variables, the prototype has a button that triggers a modal. Easy enough but here’s the issue:
Although the modal’s mode is set to Auto it does not inherit the mode from the frame it appears in. I will be great if the modal can inherit the mode of the frame it appear in.
Dennis_N
Power Member
May 2, 2024 8:59 AM UTC
Afaik this should be the case. I have a similar case where I trigger a sticky element with mouse enter and this overlay inherits the parents (dark)mode with a small delay.
Could you check again if it works? Maybe it was a bug that got fixed in the meantime.
