Hurley_Andrew_M
Oct 7, 2024 12:58 PM UTC
Design Systems Features: We want em' and we want em' now!
The team and I have been compiling a list of features we’d love to see get implemented at some point. These are primarily related to design systems and have come about as we’ve been working on improvements to our own system. Would love to know if others have found a need for other design systems related features.
Improved token/variable manager: The current token manager is pretty basic and a couple simple additions would really improve our workflows.
  • The ability to search for tokens in a given collection
  • More verbose token arrangement tools, we’ve accidentally moved the wrong set of tokens many times
  • Token mode/column arrangement, the order of the options that are displayed when changing themes is determined by this but if you set it up wrong at first or add any new mode then you can’t rearrange them.
  • Ability to natively export tokens/variables without needing a third-party plugin. Options for raw data, JSON, CSS, etc.
Theming and modes: Modes are relatively one-time use right now. But there is a growing use case for product iterations on a given theme. More specifically it would be great to be able to create a master token structure that can be utilized by other “products” or systems.
Change history: It’s pretty difficult to tell what tokens were added, deleted, or modified when pushing new versions of a library. Just listing “200” variables changes and listing whether or not they had one of three previous change types applied isn’t enough. Seeing what it changed from and to, what mode it changed for, etc. In addition revamping the version management feature to be more like Github or any other git structure where you can see a timeline of merges with notes and contributors.
Getting closer to code: Figma’s autolayout is probably the closest thing we can use to represent a coded component. But there are lots of things that could be added that would bring designs even closer to their actual implementation.
  • Add the option to change box-sizing model for the library
  • Allowing components to live inline with written content/text objects. Right now we have some pretty hacky solutions for this that are quite brittle
Other: An easier way to handle uncertain component compositions. Specifically when you have menu or list components with an unknown quantity of items within them. Right now we either have designers compose the inner menu with menu items or we’ll have a set of 10 items for them to show and hide. But the first option puts a lot of responsibility on the designer and the second option introduces file size/efficiency issues.
Lara_Pilny
Oct 8, 2024 2:17 PM UTC
Yes! All of this! Also, having token sets that auto collapse would make scrolling much easier.
Viacheslav_Poliakov1
Oct 9, 2024 11:32 AM UTC
Variables are great as a concept, but
  • Yes rearranging columns is crucial. Once I’ve spent a whole day swapping 2 modes with hundreds of variables manually with ctrl+c ctrl+v. Just to find out that due to a bug my design file does not accept swapped names of modes and I have to move all mockups to a new file to make it work.
  • Yes, search is a basic need for tables with hundreds of values.
  • Could we please have variable table columns wide enough for variable names to be readable w/o hovering? Same for the dialog that references another variable?
  • Could we please have a way to view detached/ghost variables? They can make a whole file unusable by blocking library updates!! One member of a team copies a button from an old design file with outdated variable version — welcome a whole week of using plugins to find what blocks the library from update.
  • Ability to assign variable to a component instance property (eg. I have a text component property and I want to test it with 15 languages, it is impossible ATM).
  • Please redirect keystrokes to the variables popup when it is open. I expect ctrl+a to select all variables, not all mocks on a page behind the popup I can not see.
  • Please make variables table visible for developers.
  • Please, make variable values visible for free viewers.
  • Please, allow applying color variable value as a text value (for documentation).
