Oct 27, 2023 1:52 PM UTC
Custom content slot
Whey I design a dialog component with a content slot, I’ve to create a content component to drag into. Doing this for several slots will declutter my canvas.
It would be great if you could add custom content directly within a “slot”, without the need to create a component for it.
… Like a dedicated slot where you can add content directly by clicking on it.
Peter_Staniszewski
Oct 29, 2023 12:37 PM UTC
Corey_O_Brien
May 13, 2025 12:00 AM UTC
That isn’t the same thing.
For instance, I have a modal and I want it to be essentially the same layout but I want the interior contents to be different.  I don’t have a lot of options today to make a common layout but put content into that layout.  I can use swap components now, but that still means I need to maintain a bunch of components separate from my modal component and then swap them in when needed in a particular screen.  Why can’t it be like code where I can make my screen but put my content inside of a slot, inside of the parent?  In this way, I can create my modal with my content but inherit the frame and structure from the main component.  Maintaining a hundred components to swap in and out of another component is a nighmare.
Ben_Smeets
May 13, 2025 1:39 PM UTC
I read this a couple of times, but not sure if I misunderstand what you need, but this reads as being literally the instance swap isn’t it?
