Brian_Smith
February 23, 2021
Corner Styles
  • February 23, 2021
  • 17 replies
  • 14863 views
Currently, corners can only be rounded at whatever size you set. However, it would be great if you could set different styles of corners such as inverted rounded or chamfer as you can in Illustrator.
Title_and_Untitled-1____304____CMYK_Preview_
The goal would be to create a style like the image below:
Does anyone use a plugin to achieve this effect?
Malte
July 19, 2021
As a Designer, I also feel handcuffed in this regard. I worry that the resticted toolset will only produce very similar results. To fix this, I would suggest a feature that lets you define your very own vector-based corner styles.
Kai_Magnus
July 23, 2021
Great idea is there software out there that lets you do this? Defining custom corners sounds super interesting to explore.
Doug_Wickham
October 4, 2021
The ability to round one, two, three or all four corners of a button would be great too. I know you have the ability in SKETCH to set the corner radius individually.
tank666
November 12, 2021
Hi @Doug_Wickham, setting an individual corner radius exists in Figma.
Figma Help Center
Doug_Wickham
November 12, 2021
Nice. Thanks tank
ekin_aydemir
March 2, 2022
Blender lets you define custom bevel shapes for corners. I can be wrong but It should be easier to implement that in 2d.
Santiago_Mansilla
March 3, 2023
I need this!!
Maxim_Bilous
June 5, 2023
Alicia_St_Rose
September 11, 2023
You can do this with shapes. Just put a circle shape at the corners and then subtract from the rectangle. Am I missing something in the feature request?
inverted-curved-corners|533x500
Vyacheslavskiy
April 12, 2024
Please add this. I recently moved from Sketch to Figma and I was really surprised that there is no option for different corner styles.
P.S. Subtracting shapes does not work when you start resizing.
