Nellya
Power Member
Dec 16, 2024 9:11 AM UTC
Access to your file is restricted, but on tap interaction is available only if you choose any mobile device in prototype settings. Probably you didn’t.
Jeffrey_Nevels
Dec 16, 2024 11:04 AM UTC
Nellya
Power Member
Dec 16, 2024 11:30 AM UTC
I checked your file, the problem is just like i said — no mobile device is selected.
The width of your mobile frame is 402 px, so you need to select iPhone 16 Pro here
Jeffrey_Nevels
Dec 23, 2024 3:13 AM UTC
Can you please help me understand why there is no “Content Proptery” option? I have attached a screenshot
Nellya
Power Member
Dec 23, 2024 10:09 AM UTC
It’s here in UI3
Jeffrey_Nevels
Dec 24, 2024 11:02 AM UTC
How do I download UI3? I downloaded the newest Figma update. Was that included?
Nellya
Power Member
Dec 24, 2024 11:14 AM UTC
Yes, it included in the newer version. Can you share a screenshot of your interface?
Jeffrey_Nevels
Dec 26, 2024 2:10 AM UTC
Here.
Nellya
Power Member
Dec 26, 2024 6:24 AM UTC
You already use UI3 — the newest version of Figma interface
Jeffrey_Nevels
Dec 30, 2024 1:57 AM UTC
You claim that I already use UI3. So, please see the attached screenshot and explain why the top version looks different from the bottom version. His version says “create component property” and mine says "create property or variable. Also, he has the options “Name and Value”, while my options are “Create Property, Name, and Value”. However, my value option has a slider, and his value option has a text field where he can type, “Menu button”.
