Divyal_Jain
Sep 2, 2024 12:57 PM UTC
Typography switcher not visible in appearance in left side panel.
I created my responsive typography local variables and local styles. But when I try to use that, it is not appearing in Figma side panel under appearance.
Just like themes (Light and dark) I had created typography variables for Web and mobile.
Sep 4, 2024 5:38 AM UTC
Hi there,
Thanks for reaching out. Just to clarify, would you like to switch the variable mode from the panel? If that’s the case, you can do in the right panel. If you use UI3 (new UI), there is mode switcher in the Appearance section. For UI2, it’s in the Layer section.
On the left side panel, it shows which mode is used for the layer, but I believe it’s just for display and can’t be changed from there.
Frame 27
I hope this helps but please feel free to let me know if you have more questions!
Toku
