Auto-update Thumbnails
  • June 5, 2024
  • 7 replies
  • 1310 views
Fabrice
Thumbnails will not be updated (or not predictably anyway) in the project gallery unless you perform Restore default thumbnail + Set as thumbnail sequence on the wanted frame. This problem has been around forever, would be great to finally fix it as it is pretty annoying.
Found this ticket describing it, which was closed sadly: My new thumbnail didn't refresh even after waiting 8h how to force refresh?
Joanie
  • June 5, 2024
This is happening to me as well, except performing the Restore default thumbnail + Set as thumbnail sequence on the desired frame doesn’t work for me. I can’t seem to get some thumbnails to ever appear properly. Some thumbnails show correctly, some don’t. It’s been this way for several months.
Phil_Larsen
  • Active Member
  • June 5, 2024
I’ve found it refreshes more consistently if I set the thumbnail to what I want, and then close the file… Inconvenient, I know, but the response time seems to be a bit better.
spacecat
  • July 1, 2024
I would love for Figma to fix this problem, as it’s very annoying. But in the meantime, this has been getting the job done:
  1. Make desired changes to thumbnail
  2. Option + drag to duplicate this thumbnail
  3. Wait a few seconds, then select the duplicate and choose Set as thumbnail
  4. Delete the first thumbnail that you made the changes on
  5. Reload the tab of the file you’re on
  6. Check the project page to see if it has updated – if not, reload the page
This is the only reproducible way I have found to get around the thumbnail bug(s).
Fabrice
  • July 19, 2024
Been discussing the issue with Figma support, and apparently the delay before thumbnail gets updated can be up to 60 seconds (that’s what you can expect). Just be patient 🙂
Dont_Panic
  • February 13, 2025
meshguin
  • September 25, 2025
When you set a cover/thumbnail for a file, you have to manually update the thumbnail when changes are made to the frame, instead of the thumbnail automatically updating at the Project-level.
Hoyt_Haffelder
FYI, it looks like thumbnails can’t have color variables applied to them. It needs to be a raw HEX, RGB, etc. My thumbnail and it was displaying as black, even thought it had a color variable applied to it. I broken the connection to the color variable which set the thumbnail again, and then it picked up the color.
