Irvin_Wang
Jan 31, 2024 11:08 PM UTC
Text from variables disappearing from instances with latest Figma update?
I am running into a bug only in the past 2 hours. Any instance of a component with variants that has text from a variable now won’t show the text.
Is anyone else seeing this problem? I can re create this with a very simple 1 text component.
Irvin_Wang
Jan 31, 2024 11:14 PM UTC
Here is a screenshot.
Irvin_Wang
Jan 31, 2024 11:22 PM UTC
To provide more clarity, this functionality was working fine for me up until today. I have several components whose text is a variable. Only in the past 2 hours has these texts started disappearing, first in the “Present” mode and then in all instances that I change or create.
All new components created this way also do not show text.
The only new ones that show text are if I create an instance first, and then change the text of the component to the variable. New instances created after the variable is selected will have no text as seen in the below screenshot:
Feb 1, 2024 8:35 AM UTC
Hey there,
Thanks for flagging. It looks strange. Would you be able to share the file link? I tested on my end with the latest update, and I can’t reproduce this issue.
Toku
Pinaj
Sep 13, 2024 10:05 PM UTC
I am facing the same issue, what was the resolution?
Olha_Datsenko
Sep 17, 2024 9:19 AM UTC
I have the same issue. When I run the prototype with a text variable, it displays for a second in the prototype and then vanishes. I’ve restarted Figma and cleared the cache but the problem persists.
Sep 19, 2024 5:43 AM UTC
Hi there,
Thanks for reaching out. As I checked this case internally, this issue could be a feature limitation. As a temporary workaround, could you try running the “Regenerate all instances” actions command then refreshing the file?
You can find this from the top left Figma icon >> Quick Actions >> “Regenerate all instances”.
Hope this helps.
Thanks
Sylvie_Vu
Sep 19, 2024 2:43 PM UTC
Hi still the same, nothing changed. The text keeps disappearing.
Sep 24, 2024 1:59 AM UTC
Hey there, thanks for flagging.
Then, could you submit a bug report detailing the steps that led to this issue? You can do so by following the link: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report.
Thanks for your patience.
Toku
Sylvie_Vu
Sep 24, 2024 6:02 PM UTC
Hey, thanks, I found out the reason in my case, it was on my side and I fixed it. I’m not sure how in other people’s cases.
Have a great day.
Joey Schwab
Jan 16, 2025 8:20 PM UTC
​@Sylvie_Vu would you mind sharing what the problem was and how you fixed it?
I’m experiencing the same issue – whether I edit the text of an instance using “enter” on the text layer, or set it with a variable, the text is disappearing in the prototype preview.
The strange thing is, it’s not happening in all browsers. When I’m viewing in Chrome (most recent version) it works properly, but in Safari (most recent version) it doesn’t show up. When I share the same preview link with my coworker, the issue persists in both Chrome and Safari.
​@y_toku have you been able to figure out any solutions to this issue?
